RKB enhances its range of WOR bearings
The heavy construction industry uses a big variety of highly specialized vehicles, such as concrete mixer trucks, that operate in the most rugged and adverse conditions, yet still require low-friction operation.
RKB WOR
For this very reason, the RKB spherical roller bearings WOR series, with wider outer ring, are expressly developed and engineered to accommodate large angular deflection between mixing drum and driving gear in case of misalignment. In addition, the RKB Group has recently enhanced its range of WOR bearings for both MRO applications and OEM programs by means of a new customized item (110x180x75/84 mm).
source: RKB
ZKL lanceerd Cilindrische rollager PLC_412-63
ZKL lanceerd Cilindrische rollager PLC_412-63(0)
Medewerkers van ZKL voltooie met succes de  ontwikkeling en productie van een grote dimensionale cilindrische rollager PLC_412-63 voor een belangrijke buitenlandse klant. Hierbij de technische kenmerken voor een betere voorstelling: Buitendiameter: 900 mm Hoogte: 210 mm Gewicht: 612 kg   Klik op de bron om de details te lezen. source: BearingNews
