Lubricant distributor PetroChoice buys Craft Oil in Northeast Pa
PetroChoice Holdings Inc., a Bucks County lubricant distributor, has purchased Craft Oil Corp. of Avoca, Pa. for an undisclosed sum, said Shane O’Kelly, the chief executive of PetroChoice.
PetroChoice
It was the fourth acquisition this year by PetroChoice, which was founded in 1969 in Bedford County and has been based in Bristol since it acquired Loos & Dilworth Inc. in 2009.
PetroChoice provides petroleum-based lubes and services in the Mid-Atlantic and Midwest Regions.
source: Philly.com
